View MLD Sender Information
Use this procedure to display information about the multicast senders.
- Select IPv6 MLD.
- Select the Sender tab.
Sender Field Description
Use the data in the following table to use the Sender tab.
Field |
Description |
GrpAddr |
Specifies the IPv6 multicast group address. |
Ifindex |
Specifies the interface index of the sender. |
MemberAddr |
Specifies the IPv6 host address. |
Action |
Specifies the MLD action as one of the following:
Port |
Specifies the MLD sender port. |
